Please create a new account
Sign Up Here
Learn more.
Learn more.
Remote locking steel gear differentials with cable-actuation
Steel gear transfer case
Transmission
Two speed high/low range with remote shifting
Dual horizontal shafts
Twin friction plate slipper clutch
Easily removed for servicing
Steering
Chassis mounted 2075X metal gear digital servo
Superior 45° steering angle
Steering geometry corrected for bump steer
Suspension
Front — 3 link with panhard
Rear — Triangulated 4 link
Heavy-duty rod ends with steel hollow balls
5 mm diameter steel link rods with 4 mm threaded ends
Aluminum GTS Shocks
Oil-filled coilover GTS shocks
Silver-anodized aluminum bodies
Threaded bodies with collars easily adjust ride height
Silky smooth damping for the toughest trails
O-ring cap seal and dual X-ring shaft seals
Wheels and Tires
1.9″ Canyon Trail tires with trail-tuned foam inserts
Pre-glued and mounted to tough black scale wheels
Trail tuned S1 rubber compound
12 mm steel hex
Sealed Ball Bearings
Hex hardware with Rust-Resistant Black Oxide Coating
Requires Battery and Charger (Sold Separately)
MODEL 82256-4:TRX-4 Land Rover® Defender®: 1/10 Scale and Trail® crawler, fully-assembled, waterproof, Ready-To-Drive®, with TQi™ 2.4 GHz radio system, XL-5™ HV Electronic Speed Control, and Clipless painted replica body.
What’s In The Box:
TRX-4, Ready-To-Race® model
XL-5 HV waterproof electronic speed control
Titan 21T reverse rotation motor
TQi 2.4 GHz radio system with cruise control
High quality maintenance tools
What You’ll Need:
Batteries
TRX-4 accepts a wide variety of NiMH (4–7 cell) and LiPo (2s–3s) batteries.
Charger
Traxxas EZ-Peak® Live charger is recommended for easy and fast charging performance (model 2971).
TRX-4® Land Rover® Defender® delivers innovation versatility, and capability to match its incredible scale looks. Underneath the rugged body TRX-4 Defender is built with extreme capability to take your off-road adventures to new heights. Portal axles deliver maximum ground clearance that turn “no way” into “no problem.” Whether you are enjoying outdoor trails or getting technical on the rocks, the remote-locking front and rear differentials and high/low range transmission provide unmatched driving versatility.
Scale and Trail® Crawler
Video
Chassis
Driveline
Geometry
Electronics
Scale Details
Heavy-Duty Steel Frame Rails
Adjustable Wheelbase
Molded Wire Retainers
Dual Battery Tray
Floor Pans
Aluminum Scale Shocks
Heavy-Duty Steel Links
Precision Hex Hardware
Portal Axles
Torque Twist Eliminated
T-Lock Remote Locking Differentials
High/Low Transmission
Hardened Steel U-Joints
Twin Friction Plate Slipper Clutch
Raised Center Driveshafts and Suspension Links
High Steering and Drag Links
45° Steering Angle
Extreme Approach Angles
High Ground Clearance
Front Motor Design
XL-5™ HV ESC
Titan 21T 550 Motor
Waterproof Metal Gear Servo
TQi 4-Channel Radio System
Waterproof Micro Servos with Sleeved Cables
Accessory Light Kits (sold separately)
Molded Inner Fenders
Rock Sliders
1.9″ Scale Wheels and Tires
Rugged Roll Cage
Tough Fender Flares
Secure Body Mounting System
Land Rover and the Land Rover Logo are trademarks owned and licensed by Jaguar Land Rover Limited.
