2.2" Talon Tires with Foam Inserts (2)
2.2" Talon tires are the most versatile all-terrain tires available for your 1/16 scale Traxxas model. The directional long-wear tread pattern provides extended tire life, while providing exceptional traction on most any surface. The 2.2" Talon tire integrates a soft rubber compound, large foam inserts, and a go-anywhere design that allows it to excel on asphalt as well as rocks, grass, dirt, or any other surface. The tapered tread design where the treads meet the sidewall enables the tire to slide on asphalt, to help avoid unwanted traction rolls.
