1/16 E-Revo VXL w/Battery
Model Name:
1/16 E-Revo VXL w/USB-C
Model Type:
Monster Truck
Model Speed:
30+ mph (50+ mph with dual batteries)
Model Skill Level:
2
1/16
2.4 pounds (1.09 kg)
12.9 inches (328 mm)
9.4 inches (239 mm)
Front Track:
9.4 inches (239 mm)
Rear Track:
9.4 inches (239 mm)
4.6 inches (117 mm)
7.9 inches (202 mm)
Drivetrain:
Shaft-driven 4WD
Transmission:
Heavy-duty single speed
Hardened steel bevel, sealed
Gear Ratio (Internal):
5.04:1
48 pitch
Servo(s):
2080 digital waterproof
TQi™ 2.4 GHz 2-Channel transmitter with TSM® receiver
Motor Name:
Velineon® 380
Motor Type:
Sensorless brushless
Motor Weight:
4.49 ounces (140 g)
Motor Length:
2.4 inches (61 mm) overall length, 1.9 inches (48 mm) can length
Motor Diameter:
1.09 inches (28 mm)
Motor Shaft Size:
3 mm
Motor Connector Type:
3.5 mm bullet
ESC Name:
Waterproof Velineon® VXL-3m ESC
ESC Case Size:
1.06 inches (27 mm) / 1.85 inches (47 mm) / 0.87 inches (22 mm)
ESC Weight:
1.34 ounces (38 g)
Motor Connectors:
3.5 mm bullet connectors
Battery Connectors:
ESC Power Wire:
16 gauge
ProGraphix® Painted Body
1/16 Scale pre-painted body with applied decals
High-downforce composite wing
Waterproof VXL-3m™ Electronic Speed Control
Innovative waterproof design
Three drive profiles
Sport Mode - forward / brake / reverse
Race Mode - forward / brake
Training Mode™ - 50% forward / brake / 50% reverse (patented)
High-capacity heat sink
NiMH battery packs: 6-12 cells (7.2 to 14.4 volts)
LiPo battery packs: 2-3 cells (7.4 to 11.1 volts)
Velineon® 380 Brushless Motor
Powerful 8-turn, 4000 kV design
Optimized for smooth sensorless power
Ultra high-temperature sintered Neodymium motor magnets
Gold-plated 3.5 mm bullet connectors
Maintains steering composure to allow throttle-on powerslides
Never dulls throttle or slows the vehicle
TQi 2-channel transmitter
Programmable multi-function knob
Adjustable steering and throttle percentage (dual rates)
Adjustable steering and throttle end points
Patented waterproof receiver box
Includes Battery and USB-C Charger
2-amp USB-C Fast Charger
1200 mAh Traxxas 6-cell 7.2 V NiMH battery with iD®
Fiber-Composite Monocoque Chassis
Low-CG design for improved handling
Tough skid plates for driveline protection
All electronics securely fastened to chassis
Dual Integrated Battery Compartments
Quick-release battery doors for fast pack changes
Intake and exhaust cooling vents keep battery temperatures down
Accepts 1/16 scale NiMH and LiPo batteries
Transmission and Driveline
Full-time shaft-driven 4WD
Sealed heavy-duty transmission
Adjustable slipper clutch
Sealed, silicone-filled differentials with steel gears
Heavy-duty telescoping U-joint driveshafts
Steering
Digital waterproof Traxxas 2080 steering servo
Servo horn with integrated servo saver
Suspension
Twin-arm pivot ball suspension
Progressive rocker-arm damping for extreme travel
Springs and Shocks
Inboard fully adjustable oil-filled GTR™ shocks
Adjustable pre-load collars
Red powder-coated springs
Wheels and Tires
Pre-glued Talon™ tires with high-performance foam inserts
53 mm Gemini 5-spoke chrome wheels
Rubber-Sealed Ball Bearings
Precision Hex Hardware
Backed by Unparalleled Traxxas Support and Parts Availability
MODEL 71076-8 : Fully assembled, Ready-To-Race® with Traxxas Stability Management (TSM)® , TQi™ 2.4 GHz radio system, Velineon® 380 motor, VXL-3m™ electronic speed control, 7.2 volt NiMH battery, 2-amp USB-C fast charger, and painted body.
What’s In The Box:
1/16 E-Revo VXL with painted body TQi™ 2.4 GHz radio system Quick Start Guide 7.2 volt NiMH battery with iD® 2-amp USB-C fast charger with iD
