1/10 Slash XL-5 2WD Short Course Truck w On-Board Audio
Model Name:
Slash OBA
Model Type:
Short Course Trucks
Model Speed:
30+ mph with 7-cell battery and included optional 23-tooth pinion gear
Model Skill Level:
1
1/10
4.76 pounds (2.16 kg)
22.36 inches (568 mm)
11.65 inches (296 mm)
Front Track:
Rear Track:
8.43 inches (214 mm)
13.2 inches (335 mm)
Drivetrain:
2WD
Transmission:
Metal gear Magnum 272™
Planetary steel gear
Gear Ratio (Internal):
2.72 (final drive: 12.58)
48 pitch
Servo(s):
#2075 digital high-torque waterproof
TQ™ 2.4 GHz 3-channel radio
Battery Compartment Specs:
165 mm X 49.5 mm X 23 mm / 25 mm
Motor Name:
Titan® 12T 550
Motor Type:
High-speed brushed motor
Motor Weight:
8.47 ounces (240 g)
Motor Length:
Motor Diameter:
1.41 inches (36 mm)
Motor Shaft Size:
3 mm
Motor Connector Type:
Bullet
ESC Name:
Waterproof XL-5 ESC with low-voltage detection
ESC Type:
Brushed
ESC Case Size:
1.23 inches (31 mm) / 2.18 inches (55 mm) / 0.61 inches (15 mm)
ESC Weight:
2.44 ounces (69 g)
Motor Connectors:
Bullet
Battery Connectors:
ESC Power Wire:
14 gauge
Race Replica ProGraphix® Painted Body
Pre-painted body with applied decals
Scale dimensions and looks of actual short course race trucks
Chassis nerf bars absorb impact and support the body
Scale front and rear tube-style bumpers
Traxxas On-Board Audio
Uses actual engine sounds sampled from a Pro 4X4 short course truck
Volume can be turned down or off
Completely waterproof
High-Performance Waterproof XL-5™ Electronic Speed Control
Innovative waterproof design
Sport Mode - forward / brake / reverse
Race Mode - forward / brake
Training Mode™ - 50% forward / brake / 50% reverse (patented)
LiPo and NiMH compatible with two-stage low-voltage detection
Titan 550 Motor
Powerful Titan™ 12T 550 modified motor with internal cooling fan
Oversized armature for big torque and increased power handling
Virtually maintenance-free operation
Molded wire retainer keeps motor wires secure
TQ™ 2.4GHz 3-Channel Radio System
Ergonomic transmitter with internal antenna
Traxxas #6519 3-channel micro receiver with fail-safe security
Rocker switch on the transmitter to engage “Neutral” mode
Patented O-ring sealed watertight receiver box keeps the micro receiver dry
Includes Battery and Charger
4-amp 12V DC Peak Detecting Fast Charger
3000mAh Traxxas 7-cell 8.4V NiMH battery with iD™
Tough Fiber-Composite Monocoque Chassis
Long 13.2” wheelbase for increased stability
Over 3.5-inches of ground clearance
All electronics securely fastened to chassis
Easy Access Battery Compartment
Adjustable battery hold down
Accepts 6- and 7-cell flat packs and 7-cell hump packs
Accepts many 2S LiPo battery configurations
Transmission and Driveline
Brushless-ready Magnum 272™ metal-gear transmission
Torque-Control™ slipper clutch system
Planetary gear differential with steel ring gear
Sealed gearbox protects the transmission with beefed up motor guard
External gear cover with easy clutch access
Heavy-duty telescoping U-joint driveshafts and yokes
Steering
Digital High-torque waterproof Traxxas #2075 steering servo
High-performance bellcrank system minimizes bump steer
Suspension
Adjustable steel turnbuckles
Springs and Shocks
Fully adjustable oil-filled Ultra Shocks™ with X-ring technology
Race-tuned progressive rate white powder-coated springs
Wheels and Tires
Pre-glued scale all-terrain tires with performance foam inserts
2” outer diameter, 3” inner diameter dual-profile SCT wheels
Rubber-Sealed Ball Bearings
Precision Hex Hardware
Backed by Unparalleled Traxxas Support and Parts Availability
