1/10 Slash XL-5 2WD Short Course Truck w/ TQ Radio
Model Name:
Slash
Model Type:
Short Course Trucks
Model Speed:
30+ mph with 7-cell battery and included optional 23-tooth pinion gear
Model Skill Level:
1
1/10
4.76 pounds (2.16 kg)
22.36 inches (568 mm)
11.65 inches (296 mm)
Front Track:
Rear Track:
8.43 inches (214 mm)
13.2 inches (335 mm)
Drivetrain:
2WD
Transmission:
Metal gear Magnum 272™
Planetary steel gear
Gear Ratio (Internal):
2.72 (final drive: 12.58)
48 pitch
Servo(s):
TQ™ 2.4 GHz 2-channel radio
Battery Compartment Specs:
165 mm X 49.5 mm X 23 mm / 25 mm
Motor Name:
Titan® 12T 550
Motor Type:
High-speed brushed motor
Motor Weight:
8.47 ounces (240 g)
Motor Length:
Motor Diameter:
1.41 inches (36 mm)
Motor Shaft Size:
3 mm
Motor Connector Type:
Bullet
ESC Name:
Waterproof XL-5 ESC with low-voltage detection
ESC Type:
Brushed
ESC Case Size:
1.23 inches (31 mm) / 2.18 inches (55 mm) / 0.61 inches (15 mm)
ESC Weight:
2.44 ounces (69 g)
Motor Connectors:
Bullet
Battery Connectors:
ESC Power Wire:
14 gauge
