Single-Motor Gear Cover
5677R
$3.50
Easily convert your dual-motor truck to a single brushless motor using the single motor gear cover. The one-piece gear cover keeps dirt and debris out, while allowing easy access to the pinion and spur gear. Slipper clutch adjustments are easy thanks to the exposed slipper nut. These parts give your brushless install a clean factory fit and finish. (Requires 5690X single-motor plate)
Requires 5690X single-motor plate.
