Wide Ratio Transmission Gear Set
$7.50
Ships Early December
Wide-ratio transmission gear set includes 38-tooth 1st speed gear with 13-tooth input gear and 18-tooth input gear. The wide ratio set increases the engine’s RPM change between first and second gear for greater top speed. (Wide-ratio gearing already comes stock on trucks)
Wide-ratio gearing already comes stock on trucks.
