20% Nitro Top Fuel (1 Gallon)
Only Traxxas Top Fuel is 100% certified for use in Traxxas engines. Don't take a chance with anything else.
WARNING : This product can expose you to chemicals including Nitromethane, which is known to the State of California to cause cancer, and Methanol, which is known by the State of California to cause birth defects or other reproductive harm. For more information go to
www.P65Warnings.ca.gov .
Traxxas Top Fuel® Power Plus™
Quality blended to protect our engines, and our reputation!
Why Choose Top Fuel Power Plus?
When it comes to your engine, you don't want to take chances with your fuel. Using the wrong fuel can cause hard starting, poor performance, and excessive engine wear. Some fuels can actually destroy engines, filling them full of deposits and corrosion. Over a thousand hours of dyno testing and real-world running was invested to develop the formula for Top Fuel Power Plus. That formula has been proven in hundreds of thousands of engines to provide incredible performance and excellent engine life. Only Traxxas fuel is 100% certified for use in Traxxas engines. Don't take a chance with anything else.
Ingredients Matter
Top Fuel Power Plus takes the highest quality ingredients and sophisticated blending machines to make a superior-performing fuel. Saving a few pennies using lower grade ingredients or widening the blending tolerances with lesser machines just won't do when it comes to Top Fuel Power Plus. Our engines are precision machines built to precise tolerances. The fuel must have the same intense requirements for quality and consistency. Only the absolute highest grades of methyl alcohol, nitromethane, and lubricants are used.
A Formula That Works
Top Fuel Power Plus uses both castor and synthetic oil. Synthetic oil provides excellent high-tech lubrication for your engine and allows rapid throttle response. Castor oil provides additional high temperature lubrication and over-lean protection. The oil percentages are specially balanced to provide just the right amount of lubrication for long engine life and to provide the crisp clean throttle response you demand in a car fuel. Top Fuel Power Plus also contains anti foaming agents, a wetting agent to improve engine lubrication, and corrosion inhibitors to maintain stability and peak performance in hostile Nitro environments.
Proven Reputation
The long-term performance reputation of our engines is on the line with each tank of fuel so you can be confident that the lubrication package in Top Fuel Power Plus is going to be just right, time-after-time. Top Fuel Power Plus is the only fuel that is specifically formulated for maximizing the performance of Traxxas engines. We certify that Top Fuel is simply the best fuel for your Traxxas engine.
Improve the Performance of Any Engine
Even engines that are not manufactured by Traxxas can benefit from the quality ingredients, consistency and proven reputation of premium Top Fuel Power Plus. Traxxas maintains some of the highest standards in the industry so Top Fuel Power Plus is sure to meet other manufacturer's specifications for engine warranty validation.
