Fluorescent Pink ProGraphix Spray Paint (5 oz)
Traxxas ProGraphix® RC paints deliver professional-grade, airbrush-like results with the easy application and convenience of aerosol cans.
WARNING : This product can expose you to chemicals including ethylbenzene, formaldehyde, benzene, MIBK titanium dioxide, silica which are known to the State of California to cause cancer, and toluene, benzene, MIBK which are known to the State of California to cause birth defects or other reproductive harm. For more information go to
www.P65Warnings.ca.gov .
Your Vision, Professional Results
Traxxas ProGraphix® RC polycarbonate paints deliver professional-grade, airbrush-like results with the convenience of aerosol cans. We optimized every aspect of paint application from can pressure and spray pattern to nozzle feel and paint chemistry to create ProGraphix RC paint. From body prep to finished product, it’s the best painting experience for customizing your favorite models.
Find Your Style
Traxxas ProGraphix RC paint comes in 23 dynamic colors including standard, metallic, fluorescent, specialty, candy, and chrome. No matter what look or effect you’re going for, ProGraphix RC Paint is the best choice for pro-quality results.
Total Convenience
Each ProGraphix color comes in a generous 5 oz. can, with our most popular colors also available in economical 13.5 oz. cans. ProGraphix paint requires no body scuffing and each coat dries in just minutes. Create eye-popping custom styles the easy way with ProGraphix RC paint.
The unique ProGraphix paint mixture and the can’s exclusive valve design deliver an even, precise coating with minimal effort. Masked lines are sharper, fluorescents are bright and vibrant, and custom creations can be stretched as far as the imagination.
Features
ProGraphix polycarbonate paints deliver professional-grade, airbrush-like results with the easy application and convenience of aerosol cans.
Convenient & Economical
Every ProGraphix color comes in a generous 5 oz (150 ml) can—that’s up to 50% more paint than other brands. The seven most popular colors also come in large 13.5 oz (400 ml) cans, perfect for large bodies and multiple models.
Fast Drying
Prographix paint can be recoated after just a few minutes of drying time. Heating to speed drying time is not required. Unassisted air-drying will deliver the best, most durable results.
Ultra-Fine Spray
A unique paint mixture and exclusive valve design deliver an airbrush-like spray for even, precise coating without the spatter of heavier sprays. Masked lines are sharper, blend and fade effects transition more smoothly, and full coverage can be achieved with less paint—and less weight.
Clog-Resistant Comfort Nozzle
A large nozzle with broad finger bed provides maximum comfort and control, especially during extended painting sessions. The nozzle’s free-flowing paint path resists clogging for consistent color application from start to finish.
Easy ID Can Marking
Each can of Traxxas ProGraphix paint is marked with the color name, taking the guesswork out of identifying the contents when the cap is removed.
Easy Prep
ProGraphix paint does not require you to scuff the body for full paint adhesion. For best results simply wipe the body down with isopropyl alcohol to ensure dust-free application.
Nitro Fuel Resistant
Contact with nitro fuel won’t cause dry ProGraphix paint to peel or crack.
