Battery & Charger
Sold Separately
4-Tec 2.0 VXL Chassis
Name:
4-Tec® 2.0 VXL Chassis
Type:
On-Road Car
Top Speed:
70+ mph
Skill Level:
3
1/10
14.94 inches (379 mm)
7.9 inches (200 mm)
2.43 inches (62 mm)
3.18 lbs (1.44 kg)
Front Track:
7.7 inches (196 mm)
Rear Track:
7.9 inches (200 mm)
10.1 inches (256 mm)
Ground Clearance:
0.3 inches (9 mm)
Driveline:
Shaft-driven AWD
Transmission:
Single speed direct drive
Sealed, hardened steel bevel, limited slip
48
Steering Servo:
TQi™ 2.4 GHz 2-channel transmitter with TSM
Battery Compartment Specs:
158 mm X 46 mm X 23 mm or 26 mm
Name:
Velineon® 3500
Motor Type:
Sensorless brushless
9.24 ounces (262 g)
Diameter:
1.41 inches (36 mm)
Shaft Size:
3 mm
Connector Type:
3.5 mm bullet
Name:
ESC Type:
Brushless
Case Size:
3.17 ounces (90 g)
Motor Connectors:
3.5 mm bullet
Battery Connectors:
Power Wire:
12 gauge Maxx® Cable
Adjustable Body Mounts and Chassis
Wheelbase can be lengthened or shortened by 3 mm
Accommodates most 200 mm bodies
Replica brake discs with red calipers
Velineon® VXL-3s™ Waterproof ESC
Heat sink accepts accessory cooling fan (3340)
Three Programmable Drive Profiles
Sport Mode - Forward / Brake / Reverse
Race Mode - Forward / Brake
Training Mode™ - 50% Forward / Brake / 50% Reverse (patented)
Large heat sink
Built-in two-stage low-voltage detection for LiPo batteries
Velineon 3500 Kv Brushless Motor
Ultra high-temperature sintered Neodymium magnets
Low-maintenance design
Efficient, high-speed ball bearings
Precision-balanced rotor
Steering
Precise servo saver integrated into servo horn
High-angle steering option
Low Center of Gravity (Low CG) Chassis
Positions weight low for improved handling
Smooth underside resists drag and snags
Angled front bumper improves approach angle
Modular interlocking chassis pieces
Improves rigidity and tightens tolerances
Allows for easy maintenance
Adjustable Battery Hold Down
Easy, secure battery installation
Swivels to allow different height batteries
Locks securely without pins or parts to lose
High Performance Suspension
Captured links won’t pop off
Geometry tuned for precise handling
Dual rear camber link mounts
Adjustable droop
Driveline
Full-time shaft driven 4-wheel drive
Aliminum center driveshaft with center bearing support
Direct drive
Sealed, oil-filled differentials
Springs and Shocks
Fully adjustable oil-filled Ultra Shocks™ with X-ring technology
Red powder coated shock springs feature a responsive spring rate
Wheels and Tires
Black chrome multi-spoke wheels with lug nut detail
High-performance street tires with long-wearing compound
Staggered street tires are larger in the rear
Brake calipers can be mounted in forward or trailing edge positions
Rubber-Sealed Ball Bearings
MODEL 83124-4 : 4-Tec® 2.0 1/10 scale AWD chassis, waterproof and fully-assembled with Velineon® VXL-3s™ brushless power system and TQi™ 2.4 GHz high power radio system with TSM.
What’s In The Box:
4-Tec 2.0 Chassis TQi 2.4 GHz Radio System Quick Start Guide High Quality Maintenance Tools
What You’ll Need:
Body
Standard 200 mm body
Battery Pack
4-Tec 2.0 requires a 7-cell NiMH “flat pack” or a 2-3 cell LiPo battery.
Charger
Alkaline Batteries
