1/10 Stampede XL-5 2WD Monster Truck w/ TQ Radio
Model Name:
Stampede
Model Type:
Monster Truck
Model Speed:
30+ mph with 7-cell battery and included optional 21-tooth pinion gear
Model Skill Level:
1
1/10
4.08 pounds (1.85 kg)
16.25 inches (413 mm)
12.75 inches (324 mm)
Front Track:
Rear Track:
9.5 inches (241 mm)
10.63 inches (270 mm)
Center Ground Clearance:
4 inches (102 mm)
Drivetrain:
2WD
Transmission:
Magnum 272™
Planetary steel gear
Gear Ratio (Internal):
2.72 (final drive: 12.34)
48 pitch
Servo(s):
2056 high torque waterproof
TQ™ 2.4 GHz 2-channel radio
Battery Compartment Specs:
164 mm X 46 mm X 26 mm
Motor Name:
Titan® 12T 550
Motor Type:
High-speed brushed motor
Motor Weight:
8.47 ounces (240 g)
Motor Length:
Motor Diameter:
1.41 inches (36 mm)
Motor Shaft Size:
3 mm
Motor Connector Type:
Bullet
ESC Name:
Waterproof XL-5 ESC with low-voltage detection
ESC Type:
Brushed
ESC Case Size:
1.23 inches (31 mm) / 2.18 inches (55 mm) / 0.61 inches (15 mm)
ESC Weight:
2.44 ounces (69 g)
Motor Connectors:
Bullet
Battery Connectors:
ESC Power Wire:
14 gauge
ProGraphix® Painted Body
Pre-painted monster truck body with applied decals
High-Performance Waterproof XL-5™ Electronic Speed Control
Innovative waterproof design
Sport Mode - forward / brake / reverse
Race Mode - forward / brake
Training Mode™ - 50% forward / brake / 50% reverse (patented)
LiPo and NiMH compatible with two-stage low-voltage detection
Titan® 550 Motor
Titan® 550 Motor
Powerful Titan 12T 550 modified motor with internal cooling fan
Oversized armature for big torque and increased power handling
Virtually maintenance-free operation
TQ™ 2.4 GHz 2-Channel Radio System
Ergonomic transmitter with internal antenna
Traxxas 6519 3-channel micro receiver with fail-safe security
Patented O-ring sealed watertight receiver box keeps the micro receiver dry
Includes Battery and Charger
4-amp 12 V DC Peak Detecting Fast Charger
3000 mAh Traxxas 7-cell 8.4 V NiMH battery with iD®
Tough Fiber-Composite Monocoque Chassis
Tall 4″ center ground clearance to drive over obstacles
All electronics securely fastened to chassis
Easy Access Battery Compartment
Accepts 6-cell flat packs and 7-cell hump packs
Accepts short form factor 2-cell LiPo batteries
Transmission and Driveline
Brushless-ready Magnum 272™ metal-gear transmission
Torque-Control™ slipper clutch system
Planetary gear differential with steel ring gear
Sealed gearbox protects the transmission with beefed up motor guard
External gear cover with easy clutch access
Heavy-duty telescoping U-joint driveshafts and yokes
Steering
Steering
High-torque waterproof Traxxas 2056 steering servo
Spring-loaded servo saver helps protect against impacts
Suspension
Suspension
Durable solid camber links eliminate the need for adjustment
Springs and Shocks
Springs and Shocks
Fully adjustable oil-filled Ultra Shocks™ with X-ring technology
White powder-coated springs
Wheels and Tires
Wheels and Tires
Pre-glued high profile Talon™ all-terrain tires with performance foam inserts
2.8″ Mirror-chrome All-Star™ wheels
Backed by Unparalleled Traxxas Support and Parts Availability
