Velineon VXL-4s Brushless Power System
The Velineon® 4s brushless power system takes your RC experience to the extreme with the monstrous torque of the Velineon 540XL brushless motor and innovative VXL-4s™ ESC. New High-Resolution Linear Braking provides the most intuitive and precise braking ever offered by Traxxas. Outfitted with built-in telemetry and a selectable 6.0 or 7.4-volt BEC, the VXL-4s transforms 14.8 volts of LiPo power into staggering performance. An extra large heat sink allows the ESC to run cooler for extended run times.
Fitment Guide
Direct Bolt-In Installation for Rustler 4X4.
Also fits Jato 4X4 BL-2s, Rally 4X4, and Slash 4X4 with LCG chassis using required 9030 receiver box . (Does not fit standard height chassis)
Recommended Upgrades
Extreme Heavy-Duty Upgrade Kit 9080
Center differential (6780 or 6780A ).
Battery expansion kit for 4s LiPo battery.
Spring and suspension tuning for additional weight.
New 5 mm pinion and spur gears to compensate for lower motor Kv rating (recommend 6-7 tooth increase on pinion gear.)
Stock part(s) for these models:
Name:
Velineon® 540XL
Type:
2400 Kv sensorless brushless
11.18 ounces (317 g)
3.58 inches (91 mm)
Diameter:
1.41 inches (36 mm)
Shaft Size:
5 mm
Connector Type:
6.5 mm bullet connectors
Name:
Velineon VXL-4s™
Type:
Sensorless Brushless
Case Size:
2.40″ (61 mm) x 2.09″ (53 mm) x 1.42″ (36 mm)
4.20 ounces (119 g)
Motor Connectors:
Traxxas 6.5 mm bullet connectors
Battery Connectors:
Traxxas High-Current Connectors
VXL-4s Electronic Speed Control
2s–4s LiPo compatible
Real-time telemetry via Traxxas Link™
Selectable 7.4-volt high-voltage BEC
More precise than conventional systems
Superior brake modulation on the track
Large heat sink accepts accessory cooling fan (3340)
Three programmable drive profiles
Sport Mode - Forward / Brake / Reverse
Race Mode - Forward / Brake
Training Mode™ - 50% Forward / Brake / 50% Reverse
Integrated protection circuits
LED status lights
Velineon 540XL Brushless Motor
Long format brushless motor
4-pole 2400 Kv
5 mm output shaft
Low-maintenance design
High-Voltage BEC
The Velineon VXL-4s features a high-voltage BEC with a 6.0-volt setting for standard servos and powerful 7.4-volt setting for high-performance servos like the Traxxas 2280, 2255, and 2250. Powerful brushless servos like the High-Torque 600 gain over 20% more torque at 7.4 volts with faster transit times. Selecting a voltage is quick and easy using the Traxxas Link app.
Velineon VXL-4s High-Resolution Linear Braking is a patent-pending Traxxas innovation that delivers next-level smoothness and precision. The High-Resolution communication loop allows instant response to the driver’s input for powerful and intuitive linear braking feel. From feather touch speed correction to full-power late braking to overtake on the inside line of a corner, the driver stays fully connected and in control for a competitive edge on the track. The optional Traxxas Link app adds easy control over brake force to tune for different needs and conditions.
