22-Tooth Machined Top Drive Gear
3195X
$6.00
Machined from ultra-tough POM composite, the 3195X top drive gear is more precise for less wear and friction. Provides quiet, more efficient operation. Use a light coating of silicone grease. (Note: 3195X & 1996X must be used together. A new 2388 main diff gear should also be installed.)
(Note: 3195X & 1996X must be used together. A new 2388 main differential gear should also be installed.)
