Ă—
Dual 4s LiPo Completer w/ EZ-Peak Live Dual Charger
The 2997 completer pack is the perfect complement to your 8s-equipped X-series
™ vehicle. The pack includes two
2890X 4-cell 6700 mAh LiPo battery packs for tire-scorching 30+ volt power. Traxxas iD-equipped batteries are the easiest and safest Lipo charging solution when used with our exclusive iD-equipped chargers. You just plug in your iD-equipped battery and press start. The charger handles all the settings and quickly gives you an optimized charge every time.
The 4s capable
2973 EZ-Peak
® Live Dual multi chemistry charger comes equipped with built-in Bluetooth to work with the new EZ-Peak Live
™ app for iOS and Android. The app gives you detailed information and advanced operation through a high-definition color interface. It’s the finest charger in the popular EZ-Peak iD lineup.
Battery Chemistry:
Lithium Polymer (LiPo)
Capacity:
6700 mAh
Nominal Voltage:
14.8 volts
Discharge Rate:
25c
178 mm
48 mm
45 mm
22.7 ounces
Name:
EZ-Peak® Live Dual
Chemistry Type:
LiPo/NiMH
Input Voltage:
100-240 volts AC
Charge Amperage:
1.0 - 16.0 amps (Dual Mode) Up to 26 amps total
Charge Wattage:
200 watts
Discharge Rate:
750 mAh
NiMH Cell Count:
5-8 cells
LiPo Cell Count:
2-4 cells
Dimensions:
200 mm x 174 mm x 68 mm
916 grams
200 watt 26+ amp max output Charges Dual 5-8-cell NiMH batteries Charges Dual 2s, 3s, and 4s LiPo Batteries Recognizes iD-equipped batteries to optimize charger settings automatically MAXX Charge feature gets you back in the action quickly Optimized for faster LiPo balance charging One button LiPo storage charge protects your battery investment Advanced high-resolution peak detection delivers a perfect charge Easy to use interface with dual LED charge progress indicators Supports Traxxas EZ-Peak Live Application Audible alerts Dual high-flow cooling fans Advanced Mode for full manual control through EZ-Peak Live App Legacy support for all Traxxas High-Current Connectors Integrated dual balance ports for legacy LiPo batteries Built-in 2-amp USB charger output port
iD Technology
There has never been an easier or safer way to charge your batteries than the Traxxas iD® system. Just plug in a Traxxas iD-equipped battery and press start - that’s all there is to it! Traxxas pioneered this exclusive technology to eliminate complicated charger programming. The iD system detects which Traxxas iD-equipped battery you are using and automatically configures the settings for the optimal charge. The progress bar and audible alerts keep you informed while the advanced high-resolution peak detection delivers a perfect charge every time. The EZ-Peak Live’s Storage Mode protects your LiPo battery investment by safely preparing the batteries for extended storage.
MAXX Power
Faster charging means more time behind the wheel. The new MAXX Charge feature takes full advantage of LiPo batteries’ high charge rates. Press the MAXX Charge button and the right side charges at the maximum charge rate the battery will allow (up to 16 amps). The left side receives the remaining power until the right side finishes and then the left side switches to MAXX power mode. This innovative design gets one battery ready in nearly half the time so you’re back in the action having fun.
Charging Flexibility
The EZ-Peak Live Dual multi-chemistry charger automatically detects the type and size of your iD-equipped battery and configures the settings for the fastest charge possible. With 200 watts of power on tap, EZ-Peak Dual maximizes its charging potential for NiMH and LiPo batteries. Even the largest 4-cell LiPo batteries are no problem with up to 16 amps of charging horsepower per side. Two high-flow fans keep the temperature down for extended charging sessions. Dual balance ports provide backwards compatibility for legacy batteries. There’s even a 2-amp USB output to charge your mobile device. No other charger features EZ-Peak Live’s combination of power and flexibility with iD safety and simplicity.
Technology
Traxxas pushes the technological envelope to provide you the fastest, most convenient charging experience possible. Not only is EZ-Peak Live Dual our most powerful charger ever, it’s also our most advanced. The free EZ-Peak Live App installs on your Apple® or Android™ device and links to your charger via built-in Bluetooth® . The EZ-Peak Live App gives you access to additional features, such as a high-definition graphical user interface, firmware upgrades, remote monitoring and alerts for up to 4 chargers, detailed live charging information, and the ability to turn off iD mode. iD mode may be switched off through the EZ-Peak Live Application for charging legacy batteries with non-iD Connectors. This is charging the Traxxas way—fast, easy, and more advanced than ever!
