EZ-Peak 40-Watt USB-C Multi-Chemistry Charger
$39.95
Ships Mid October
Power and Convenience
Get fast 4-amp multi-chemistry charging virtually anywhere with the Traxxas USB-C NiMH/LiPo battery charger with iD® technology. The 4-amp NiMH/LiPo balance charger is the perfect solution for your charging needs with 5-7 cell NiMH and 2-3 cell LiPo capability.
The Traxxas iD system is the easiest and safest way to charge your Traxxas batteries. The charger automatically determines the type of iD-equipped battery being charged and optimizes the charge settings as soon as you plug it in. There’s no guesswork involved, just fast, reliable charging every time. Learn more about Traxxas iD technology here.
  • Powered by conventional USB-C power supply
  • Charges 5-7 cell NiMH and 2-3 cell LiPo batteries
  • 40+ watt 4-amp max output
  • Auto-recognizes Traxxas iD-equipped batteries
  • Optimizes charge settings
  • LED progress indicator
Full 40-watt charging output requires a 45 watt or greater power supply like the Traxxas 2912 and high-quality USB-C cable like the Traxxas 2916
