EZ-Peak 8-Amp 4s Multi-Chemistry Charger
$99.95
Ships Late July
Just plug a Traxxas iDĀ®-equipped battery into the EZ-PeakĀ® Plus 4s and press Start. Traxxas iD technology does the rest. The charger automatically detects the type of iD-equipped battery you are using and then configures the settings for the fastest charge possible. With up to 8 amps of charging power, the EZ-Peak Plus 4s is the fastest, easiest, and most convenient way to charge your Traxxas batteries. EZ-Peak Plus 4s charges both NiMH and LiPo batteries (up to 4s), and even legacy batteries with external balance leads using the built-in balance port.
