1/10 Bandit VXL 2WD 3S Brushless Extreme Sports Buggy
Model Name:
Bandit VXL w/TSM
Model Type:
Buggy
Model Speed:
70+ mph with 3s LiPo battery and optional 33-tooth pinion gear (sold separately)
Model Skill Level:
2
1/10
3 pounds (1.36 kg)
16.25 inches (413 mm)
9.84 inches (250 mm)
Front Track:
Rear Track:
7 inches (178 mm)
11.25 inches (286 mm)
Drivetrain:
2WD
Transmission:
Magnum 272™
Planetary steel gear
Gear Ratio (Internal):
2.72 (final drive: 7.97)
48 pitch
Servo(s):
TQi™ 2.4 GHz 2-channel transmitter with 6533 receiver
Battery Compartment Specs:
166 mm X 47.5 mm X 28 mm
Motor Name:
Velineon® 3500
Motor Type:
Sensorless brushless
Motor Weight:
9.24 ounces (262 g)
Motor Length:
Motor Diameter:
1.41 inches (36 mm)
Motor Shaft Size:
3 mm
Motor Connector Type:
3.5 mm bullet
ESC Name:
ESC Type:
Brushless
ESC Case Size:
ESC Weight:
3.17 ounces (90 g)
Motor Connectors:
3.5 mm bullet
Battery Connectors:
ESC Power Wire:
12 gauge Maxx® Cable
