1/10 Bandit XL-5 2WD Extreme Sports Buggy with TQ Radio
ProGraphix® Painted Body
Pre-painted body with applied decals
Aggressive, aerodynamic body with rear wing
High-Performance Waterproof XL-5™ electronic Speed Control
Innovative waterproof design
Sport Mode - forward / brake / reverse
Race Mode - forward / brake
Training Mode™ - 50% forward / brake / 50% reverse (patented)
LiPo and NiMH compatible with two-stage low-voltage detection
Titan® 550 Motor
Powerful Titan 12T 550 modified motor with internal cooling fan
Oversized armature for big torque and increased power handling
Virtually maintenance-free operation
TQ™ 2.4 GHz 2-Channel Radio System
Ergonomic transmitter with internal antenna
Traxxas 6519 3-channel micro receiver with fail-safe security
Sealed watertight receiver box keeps the micro receiver dry
Includes Battery and Charger
3000 mAh Traxxas 7-cell 8.4 V NiMH battery with iD®
Tough Fiber-Composite Monocoque Chassis
Wide, low-profile design for increased stability
All electronics securely fastened to chassis
Easy Access Battery Compartment
Accepts 7-cell flat packs and hump packs
Accepts 2-cell LiPo batteries
Transmission and Driveline
Brushless-ready Magnum 272™ metal-gear transmission
Torque-Control™ slipper clutch system
Planetary gear differential with steel ring gear
Sealed gearbox protects the transmission with beefed up motor guard
External gear cover with easy clutch access
Heavy-duty telescoping U-joint driveshafts and yokes
Steering
High-torque waterproof Traxxas 2056 steering servo
High-performance bellcrank system minimizes bump steer
Suspension
Durable solid camber links eliminate the need for adjustment
Springs and Shocks
Fully adjustable oil-filled Ultra Shocks™ with X-ring technology
White powder-coated springs
Wheels and Tires
Pre-glued Alias®
2.2″ black and chrome multi-spoke wheels
Backed by Unparalleled Traxxas Support and Parts Availability
