Machined 30-Tooth Idler Gear
1996X
$12.00
The machined 30-tooth idler gear is more precise than standard gears for less wear and friction. Use a light coating of silicone grease. Not for use with steel top gears. (Note: 3195X & 1996X must be used together. A new 2388 main differential gear should also be installed.)
(Note: 3195X & 1996X must be used together. A new 2388 main diff gear should also be installed.)
