Battery & Charger
Included
1/18 LaTrax Teton
Name:
LaTrax® Teton®
Type:
Monster Truck
Skill Level:
1
1/18
15.2 ounces (430 g)
10.16 inches (258 mm)
Front Track:
4.17 inches (106 mm)
Rear Track:
4.23 inches (108 mm)
4.65 inches (118 mm)
6.44 inches (164 mm)
Center Ground Clearance:
1.18 inches (30 mm)
Driveline:
Shaft-driven 4WD
Transmission:
10-T pinion / 60-T spur
Hardened steel bevel (ring and pinion)
Gear Ratio (Internal):
2.5:1
0.5 module
Steering Servo:
2065 waterproof
2.4 GHz 2-channel radio
Battery Compartment Specs:
102 mm X 35 mm X 18 mm
Tough Truck Body
1/18 scale pre-painted body with applied decals
Adjustable-height body mounts
Waterproof Electronic Speed Control
Innovative waterproof design
Fully-proportional forward, reverse, and braking control
Three drive profiles
Sport Mode - forward / brake / reverse
Race Mode - forward / brake
Training Mode™ - 50% forward / brake / 50% reverse (patented)
EZ-Set® one-button setup
Thermal shutdown protection
Motor
Powerful 370 brushed motor
Virtually maintenance-free operation
2.4 GHz 2-Channel Radio System
Ergonomic transmitter with internal antenna
3-channel micro receiver with fail-safe security
Servo reversing
Electronic steering trim controls
Includes Battery and Charger
AC wall-outlet charger
1200 mAh 6-cell 7.2 V NiMH battery with iD®
Fiber-Composite Chassis
Impact-absorbing front and rear bumpers
Quick-release battery hold-down for fast battery changes
Transmission and Driveline
Full-time shaft-driven 4WD
Metal-gear front and rear differentials
Steering
Waterproof sub-micro steering servo
Integrated servo saver
Suspension
4-wheel fully independent suspension
Springs and Shocks
Oil-filled coil-over shocks with variable mounting positions
Wheels and Tires
Aggressive off-road tires pre-glued to 5-spoke wheels
MODEL 76054-5 : LaTrax® Teton® : 1/18 scale off-road truck, fully assembled, Ready-To-Explore® , with 2.4 GHz radio system, 370 motor, waterproof, all-weather electronics, 7.2-volt NiMH battery & AC wall outlet charger, and painted body.
What’s In The Box:
LaTrax Teton with 370 Motor Quick Start Guide 2.4 GHz radio system 7.2-volt NiMH battery AC wall outlet charger Four Traxxas Power Cell AA alkaline batteries
