Aluminum Center Driveshaft
10757X
$8.00
This aluminum driveshaft is shorter than the standard driveshaft to accommodate the optional 10758 slipper clutch or 10760-series center differential.
When using the aluminum driveshaft, you must also use differential pinion gear 10762.
