4-Tec Green Underbody LED Light Kit
10590-GRN
$34.95
Give your 4-Tec® 2.0 or 4-Tec Drift® extra style points with this underbody LED light kit. Perfect for track competitions or parking lot hooning, the underbody LED light kit casts a colorful glow underneath the car. The light kit is compatible with 4-Tec Drift and most 200 mm bodies fitting the 4-Tec 2.0 chassis. The LED light strips are sealed inside a tough housing that mounts securely to the sides of the chassis with the provided hardware. The included 3-volt power supply connects directly to the battery using the included power tap for smooth, consistent light output from beginning to end.
