Troubleshooting - Glow plug wire damaged
Article #10143
Examine the blue wire that joins the EZ-Start® connector in the model to the glow plug. Look for any breaks in the wire or tears in the insulation, which could cause a short against the motor or chassis. Any breaks in the wire may be repaired and taped or, if the blue wire is badly damaged, it can be replaced separately as Traxxas part #4581. Try sliding a piece of fuel tubing over the wire to protect it from being cut or damaged.
TRX .15
TRX 2.5
0
Your rating: None
