Troubleshooting - Engine stalls when brakes are applied
Article #10184
- Transmitter throttle trim not adjusted properly
- Adjust throttle trim on TQ transmitter
- Engine idle speed set too low
- Increase idle speed TRX 2.5/3.3 or Pro.15.
- Low speed needle too rich
- Adjust the TRX 2.5/3.3 or Pro .15 Low speed needle setting. See also carburetor care for more information.
- Brake linkage not set properly
- Re-center the throttle/brake servo and adjust linkage.
- Broken clutch spring in clutch bell
- Replace clutch shoes and clutch spring
