Troubleshooting - Engine overheats
Article #10176
- Improper or contaminated fuel
- Replace the fuel. Traxxas recommends using Top Fuel.
- Excessive nitro in the fuel
- Use fuel with a lower nitro content. Recommended nitro content for Traxxas engines is 10% to 33%.
- Incorrect oil content in the fuel
- Switch to a recommended brand of fuel. Traxxas recommends Traxxas Top Fuel for all Traxxas engines.
- Readjust carburetor to factory break-in settings. When using fuel with 10% nitro, the hi-speed mixture setting should generally be 1/2 turn leaner.
- Low-speed fuel mixture is too lean
- Richen the TRX 2.5/3.3 or Pro .15 Low speed needle setting. See also carburetor care for more information.
- High-speed fuel mixture is too lean
- Richen the TRX 2.5/3.3 or Pro .15 High-Speed fuel mixture setting.
- Fuel flow blocked
- Check that all fuel lines are clear with no pinhole leaks. Check for dirt blockage in the carburetor fuel inlet and high speed needle seat/ Install inline fuel filter.
- Air bubble in fuel line
- Prime the engine to force air through/ Check for pinhole leaks in the fuel line
- Cooling air to head is blocked
- Cut ventilation holes in the body (windshield)
- Excessive load on the engine
- Check for bound drivetrain
(11 votes)
