Traxxas Skill Level Guide
Article #23096
Choose the Model That is Right For You.
The below skill level guide provides a good overview of our product lineup. The skill levels range from 'Skill Level 1', which requires no prior radio control experience to our highest rating, 'Skill Level 5', that is for expert drivers only. The fastest vehicle may be the most appealing, but we recommend starting with a 'Skill Level 1' or 'Skill Level 2' vehicle to insure a successful entry into the radio control hobby. We're confident that your venture into hobby-class radio control modeling will reward you with nothing but great times. So, go have some fun, and thank you for considering Traxxas.
nid%3D23113%7Ctitle%3D%7Cdesc%3D%7Clink%3Dnone nid%3D23112%7Ctitle%3D%7Cdesc%3D%7Clink%3Dnonenid%3D23114%7Ctitle%3D%7Cdesc%3D%7Clink%3Dnone
nid%3D23115%7Ctitle%3D%7Cdesc%3D%7Clink%3Dnonenid%3D23116%7Ctitle%3D%7Cdesc%3D%7Clink%3Dnone
No previous experience with radio controlled models is required. Models require a minimum of setup, maintenance, or support equipment.
nid%3D23117%7Ctitle%3D%7Cdesc%3D%7Clink%3Dnone nid%3D23118%7Ctitle%3D%7Cdesc%3D%7Clink%3Dnonenid%3D23119%7Ctitle%3D%7Cdesc%3D%7Clink%3Dnone
nid%3D23120%7Ctitle%3D%7Cdesc%3D%7Clink%3Dnonenid%3D23121%7Ctitle%3D%7Cdesc%3D%7Clink%3Dnone
Previous experience with radio controlled models is recommended. Models require a higher level of setup, maintenance, or support equipment.
nid%3D23122%7Ctitle%3D%7Cdesc%3D%7Clink%3Dnone nid%3D23123%7Ctitle%3D%7Cdesc%3D%7Clink%3Dnonenid%3D23124%7Ctitle%3D%7Cdesc%3D%7Clink%3Dnone
Previous experience with radio controlled models is mandatory. Models require detailed setup, and/or maintenance procedures with required support equipment. These models are capable of high speeds, requiring experienced driving control.
nid%3D23125%7Ctitle%3D%7Cdesc%3D%7Clink%3Dnone nid%3D23126%7Ctitle%3D%7Cdesc%3D%7Clink%3Dnonenid%3D23127%7Ctitle%3D%7Cdesc%3D%7Clink%3Dnone
Previous experience with radio controlled models is mandatory. Models require detailed setup, and/or maintenance procedures with required support equipment. These models are capable of very high speeds and require an even higher level of skilled driving control.
nid%3D23128%7Ctitle%3D%7Cdesc%3D%7Clink%3Dnone nid%3D23129%7Ctitle%3D%7Cdesc%3D%7Clink%3Dnone
For Expert Drivers Only. Previous experience with nitro-powered radio controlled models is required! These models are capable of extreme speed and acceleration! They carry our highest skill level rating and are intended for expert drivers only.
4.23077
Your rating: None Average: 4.2 (13 votes)
