Traxxas Engine Replacement Plan
Article #23152
Traxxas Engine Replacement Plan (ERP)
Traxxas Power-Up Program and the Lifetime Engine Replacement Plan
Years ago we saw a need for our customers to have an easy and affordable way to protect their investment in their Traxxas nitro model and keep the engine performance factory-fresh. Our solution is the Lifetime Engine Replacement Plan, which is part of our exclusive Power-Up Program.  Engines wear out over time and need to be rebuilt. Rebuilding engines from parts can be costly and time consuming, and can be outside the mechanical skills of many enthusiasts. With the Traxxas Lifetime Engine Replacement plan, a worn out or damaged engine can be traded in for a brand-new, factory-fresh TRX® Racing Engine right away by simply exchanging your worn engine at your local hobby store. The cost is 1/2 of the retail price of the new replacement engine. It’s less expensive than rebuilding the engine yourself and you get the peace of mind knowing your engine is brand new (not refurbished), and ready to deliver the power and reliability you expect. In many cases, installing the new engine only takes minutes and you're back in action.
Extreme Upgrades
In addition to allowing you to replace your Traxxas engine with the same model to restore original, factory-fresh performance, the Power-Up Program is the extreme-power upgrade path for any model equipped with a TRX® 2.5 or TRX 2.5R Racing Engine. When you’re ready, you can use the plan to trade up to the TRX 3.3 Racing Engine and watch your speed and acceleration soar. The TRX 3.3 is 100% “drop-in” compatible with TRX 2.5 and 2.5R equipped models. For less than the price of an average, poorly supported aftermarket engine, you can have extreme TRX 3.3 power with 100% drop-in installation, EZ-Start® electric starting, full Traxxas reliability and support, and power that is absolutely second to none. If you are a TRX® Pro.15 owner, you can trade up to TRX 2.5R power or, if you dare, the TRX 3.3 Racing Engine. $25 conversion kits are available that make it easy to install the rear exhaust, slide carb equipped TRX Racing Engine in place of the TRX Pro.15. Ask your hobby dealer for all the details.
The Power-Up Program now allows the exchange of a Traxxas nitro engine (TRX® Pro.15, TRX 2.5, or TRX 2.5R) for the ultimate power of the TRX 2.5R or TRX 3.3 Racing Engines. Nitro Sport, Nitro Stampede, and older Traxxas nitro model owners can now easily and affordably upgrade to the same powerful and good looking TRX 3.3 Racing Engine that powers the top-of-the-line Revo®.
For full details of the Power-Up Program, Click Here.
4.95
Your rating: None Average: 5 (20 votes)
