Tranny makes grinding noises
Article #10199
- Stripped transmission gears
- Replace damaged gears.
- Stripped or worn spur gear
- Replace the spur gear before continuing to run the model.
- Differential damage (Maxx/Revo trucks)
- Remove and inspect the front or rear differenital to check the ring and pinion gear for damage. Replace the necessary parts using your vehicle's exploded view drawings for reference.
