Model glitches and stutters (Blast)
Article #17381
- Onboard batteries not properly charged
- Replace, or Charge battery completely.
- Servo lead wires are cut or frayed
- Fix or send the servo back to Traxxas for repair.
- Antenna lead cut, or damaged
- Fix or send the receiver to Traxxas for repair.
- Damaged frequency crystal
- Replace the damaged crystal set (RX & TX) before continuing to run the model.
- Motor is dirty or damaged
- Give the motor a thorough cleaning and then install it back on the motor mount.
- Batteries in the transmitter are weak, or completely discharged
- Check for a bright red LED on transmitter. If the transmitter's LED blinks, install fresh batteries before continuing to run the model.
- Receiver or transmitter failure
- Return the component to Traxxas for service.
- Frequency conflict
- Someone nearby may already be using your frequency. Try another frequency or go to another area.
- ESC requires setup
- Follow the instructions shown in your manual for basic ESC setup.
