Drive belts are skipping
Article #10211
- Loose belts
- Adjust belt tension or replace the stretched belt.
- Stretched belts
- Replace the stretched belt.
- Damaged Belt
- Inspect the belts for missing teeth. Debris can damage the belts teeth from normal operation. If the belts have any missing teeth, replace the belt.
- Loose bulkhead mounts
- Inspect the bulkheads and belt pullies for missing hardware or screws that may be allowing the assembly to move and alter belt tension.
