Cracks in the hull
Article #10210
  1. Nitro from fuel has come in contact with hull
    Perform normal maintenance on hull. After each day of running, clean hull with denatured alcohol to remove oil and dirt from the hull.
  2. Dropping or driving boat into solid object
    Watch for objects while you are driving. Do not drive boat on shallow water or close to shore.
  3. Hole or crack in exhaust tube (Nitro Vee)
    Replace the exhaust tube.
  4. Storing boat in direct sunlight
    ABS plastic must be kept out of direct sunlight during storage.
0
Your rating: None
