Boat won't plane
Article #10206
  1. Carburetor incorrectly adjusted(Nitro Vee)
    Readjust carburetor to factory break-in settings
  2. Prop is damaged
    Replace prop.  Refer to your parts list or exploded views for the correct part number.
  3. Loose or broken driveshaft or drive cup
  4. Incorrect outdrive angle
    Set outdrive angle in line with bottom of boat.
  5. Vacuum created between boat and water
    Drive the boat with quick right and left movements to break vacuum.
0
Your rating: None
