with a pro.15 engine please name some good ones for racing.
any one some one has to know.![]()
for racing, i would recommend either the paris turbo ring pipe, or associated GT pipe. both offer good bottom end response and are legal for racing.
TRAXXAS:The Team To Watch!!
iam getting the traxxas blue pipe for nitro rustler
I've been pleased with the performance of MIP's stinger. Although, there is one thing that I should point; the included rear shock-tower is mounted with only two screws. The screws tend to vibrate loose, and since they are rather difficult to access without removing the engine, I suggest using something like LocTite 425 to hold them in place.
Here's a link to the pipes: http://www.miponline.com/stingers.html
dude, u must be putting the screws in the wrong way!! The head of the screws are suppose to be pointing out the back the the truck not into the engine!!
T-maxx, Vintage TRAXXAS Nitro Hawk, HPI Nitro MT, Project npede.
I have the traxxas blue pipe.runs good with the trx 12 motor.Just put the trx pro15 in my hawk will find out how good that works![]()
DAN (go leafs go)
Nitro Hawk,RC 10L,Ofna Hodr,mini T, Tamiya mini cooper
Npede, it's obvious that you don't have a Hawk/Stinger combination, because there's only one way to mount the aftermarket shock-tower. I suggest that you get your facts straight before making a fool of yourself.
The MIP shock-tower doesn't use the factory mounts. Instead, it mounts to the camber tie-rod anchors. In order to compensate for the shift in positioning, the rear shocks are mounted on the front-side of the shock-tower. If I were to attempt to position the shock-tower on the rear face of the camber tie-rod anchors, my shocks would probably bind, and I'd have no place to anchor my camber tie-rods.
dude, I didnt buy the stinger pipe that is made for the nitro hawk. I took the old stinger pipe off my npede and put it on my nhawk. I still have the stock shock tower on it. I figured it mounted the same way as the stock one. Well use some thread lock or silicone to hold the screws in. Or get a longer set of screws with nuts. Then they wont come out.
