My rustler is giving me some jip fuel wise.I am having difficulty getting fuel to flow from the tank to the carb.I have recently refitted my 360 stinger pipe and in doing so have brought about this problem.The fuel wont prime the carb with my finger covering the exaust.The pipe has never had a pressure nipple fitted to it, so the fuel pipe used between the tank and exaust is just squeezed into the hole.If i blow down the the pipe the fuel flows no problem.This problem is also causing the car to stall and prevents it from reving out. Another problem i have with another car, is air bubbles in the fuel line at the needle jet side of the fuel line.They return even after re-priming the carb and forcing the air bubbles out.CAN ANY BODY HELP.
