    2,063
    Traxxas Wheelie Bar doesnt fit???
    Ive had the rpm Bumper Mounts for a while now and first off they are very strong and I recommend them except for Ime breaking bodies from lid skids so I purchased a traxxas e revo wheelie bar and by rights it should bolt right up, but the rpm bumper mount has a rounded section that so happens to need to be flat for the wheelie bar to mount.
    see the rounded section between the 2 mounting screws
    and it needs to be flat like the wheelie bar mount
    and this is as far as I can jam it on
    ive already bent 2 integy wheelie bars so this is about my closest option, has anyone mounted an e revo wheelie bar to the rpm mount or does anyone have any ideas on mounting this?
    Aug 2014
    Stratford,WI
    41
    I would customize the wheelie bar to fit the summit
    1/10 Summit
    Sep 2013
    Maysville,Ky. USA
    568
    You could try heating up the curved part and try to straighten it or cut it out and hope the 2 bolts are strong enough to hold.
    2,063
    thanks for the replies......I might have to customize something to make it work, ive tried in the past to heat and bend rpm stuff and it just weakens it too much...if I cut the piece out then ill have to relly on the 2 bolts holding it on from the bottom.
