Results 1 to 3 of 3
    Aug 2013
    130
    3s lipo and gearing
    Im new to the 3s lipo. Can i keep the stock gearing with this and be good for bashing. the most i have gotten my motor up to is around 130 degrees or a little more. there is so much torque with the 3s throttle control plays a huge part but just wandering what the stock tooth is and if i should change it.
    May 2013
    Erie, PA
    719
    Stock is 11t in the vxl p4de. Its ok to use the 11t for bashing with 3s, just keep an eye on your temps. If they get to hot, try a 9t pinion
    The message above or below may or may not be true
    Wales in the UK
    5,628
    If you're getting around 130f on 3s stick with it and as said by hirschowl stock is 11t I ran mine between 11-13t when I had the vxl system but it only lasted 18 months before it gave out.....peace
