Results 1 to 21 of 21
    Feb 2014
    133
    MM2 2650 in rally
    i got the 2650 motor and MM2 ESC, have some questions...
    how do i mount the ESC to the chassis ? is there a mounting plate to buy ?
    i guess i buy the traxxas mount holder with the space on top for the fan like the erevo ?
    what pinion/ spur should i be running for bashing ?
    Do I have to buy the erevo slipper clutch ?
    Anything else I need ?
    thanks guys !
    Jan 2003
    nc
    2,073
    Quote Originally Posted by chris.k View Post
    how do i mount the ESC to the chassis ? is there a mounting plate to buy ? get the traxxas mount
    i guess i buy the traxxas mount holder with the space on top for the fan like the erevo ?yes
    what pinion/ spur should i be running for bashing ? I would start at 18/54 and go up from there
    Do I have to buy the erevo slipper clutch ? I would
    Anything else I need ? You will be needing axles if you haven't already upgraded them, MIP,Tekno, ect
    thanks guys !
    I hope this helps. Check out Viper z's rally build. all info there and more.
    E-revo mmm/2200
    100+mph tc4 neu powered
    Jul 2013
    Saskatoon, SK. Canada
    2,163
    Thanks for the press Phildogg!
    Chris, you need TRX 5626, it a mounting plate for the ESC
    http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXXFD3
    As Phildogg suggested for the rest
    Feb 2014
    133
    Thanks guys. I am an avid follower of vipers thread but wanted to be sure.
    So what part number is the erevo clutch parts ? Is it the rebuild kit or something else ?
    Does 5626 actually have a plate aswell as that top mounted thing or do I just stick the esc direct to the chassis ? or to the original mounting plate and screw 5626 into it ?
    Long Beach, California
    6,772
    no mounting plate needed or the included screws cant reach to the treaded holes on the chassis although, you can put some kind of cushion....., like on mine, I put double sided tape under the ESC and left the other sticky side sealed.
    Jul 2013
    2,163
    The E Revo clutch is TRX 5352R
    http://www3.towerhobbies.com/cgi-bin...&I=LXZUH8&P=ML
    As for mounting the ESC, I use the foam that came with the ESC, that strange shaped one? I peel off the one side backer and stick it to the bottom of the ESC. I leave the other side on. This acts to make a tighter fit to the chassis. The I just crew it in place. Be sure to pull the mounting post's away from the drive shaft as you tighten, as this is a close fit, and can drag against the shaft if not placed carefully.
    Here is the MM2 mounted in my Ultimate with the 2400kv the proper way, with Rx box mounted at the nose of chassis.
    Here they are mounted in the Ultimate and Rally flipped 180 degrees to accommodate the custom Rx mount and Chassis brace
    Feb 2014
    133
    MM2 2650 in rally
    Thanks guys.
    So with the clutch kit, do I pull out the rally one and use the erevo parts ?
    How did you mount the receiver box in the nose ? Screwed or tape ? I hope all the wires reach that far ! lol
    Port Alice, BC, Canada
    1,300
    MM2 2650 in rally
    The RX box screws in up front. And yes you replace the parts with the Revo parts.
    6,772
    and make sure to put the pressure plate pin on shaft's 2nd hole, away from the diff. the receiver box held by 2 countersunk screws underneath the receiver so you have to pry out the receiver.
    Jul 2013
    2,163
    The wires will reach to the RX box at the nose.
    Feb 2014
    133
    My kit finally came today. Do I need to get 5351 slipper pressure plate ? I have the standard 5556 and the plate looks too small for 5352x...or doesn't that matter ?
    also, just checking that i can use the STRC aluminium motor plate with the 2650 motor aswell.
    huma...what do you mean by the shafts 2nd hole away from the diff ?
    thanks !
    6,772
    thanks !
    Ok, if you take apart the slipper clutch assembly, you see two hole on the shaft and installing revo slipper clutch you have to put the pin onto the 2nd hole away from the diff.
    1,300
    Yup you can use strc lcg motor plate. This is the HCG plate.
    Feb 2014
    133
    Thanks, I think that's the position of my current assembley from what I can see.
    What about the pressure plate in the picture ? That doesn't look right to me.
    6,772
    Something is not quite right about your picture, are you using revo slipper presssure plate on stock clutch assembly? You need the whole revo clutch assembly.
    Feb 2014
    133
    I bought 5352r, the rest is stock. I take it I need more than that.
    Feb 2014
    133
    Looks like I definately need 5351
    6,772
    yup you definitely do need them
    http://www.ebay.com/itm/Traxxas-Revo...item51bbc5f060
    Feb 2014
    133
    all working. just a wire cleanup to go. surprised how easy it all fit in. tested it outside and its very quick. does it only work with 3s btw ? can i run 2s aswell ?
    thanks for your help guys.
    1,300
    MM2 2650 in rally
    Yup it drops right in and easy to install 👍 does your rally wheelie now lol? I know with my sl4sh MT I've yet been able to hit more than 3/4 throttle. Not even 3/4 but pretty close and I hit 40mph and that's with 3s. I need to tweak the slipper a little more and then I'm gonna play with torque limiting see if I can't get her wide open.
    Feb 2014
    133
    Quote Originally Posted by Stephan81 View Post
    It was pretty horrendous to begin with. lol
    I lowered it and put some different wheels/tyres on that which are a bit looser and then dropped it even lower and now it works great. If I put the banditos on it backflips. lol they are wayyyyyy to grippy.
