Results 1 to 14 of 14
    Jun 2014
    6
    Pleas help upgrade My Villain Iv
    Just like the title says. Can someone please get me a parts list of what I need to upgrade my stock Traxxas Villain Iv.
    So far I am looking at this ????
    http://www.offshoreelectrics.com/pro...-C-1100&cat=16
    And I already bough the cooling kit
    I have had the boat for like 8 years. It has been sitting for 2 years and I want to get back into it. I have tried searching its just confusing me more the more I look.
    Thanks a lot
    Zeeland Michigan
    1,197
    I would stay with stock props , it don't take much to ding up props , go with the Villain EX props for better speed and performance . imo
    1 Rusty VXL
    Jun 2014
    6
    Quote Originally Posted by rhardy60 View Post
    I will not be driving it in shallow water. It will be mostly used in a big pool, lake Erie and ponds not around any beaches
    Mar 2003
    Wherever the road takes me.
    36,936
    I second the EX prop suggestion, as that is what I run on my upgraded IV. That prop kit would be another good option, though.
    As for getting it running after several years of sitting, be sure to go through the drive train and inspect it well. Lubricate the drive shafts and the motor bushings, check for any binding, etc.
    Jun 2014
    6
    Quote Originally Posted by cooleocool View Post
    It works great I just used it yesterday.
    How do I know what props I have now. It rips pretty good for what it is
    Do I need the ex shafts as well or just the props?
    Zeeland Michigan
    1,197
    Quote Originally Posted by Anythingcanhappen View Post
    Just props . they'll fit right on . The EX props are bigger in size .
    1 Rusty VXL
    Jun 2014
    6
    Another question. How do you get the props off? I took the allen head off on the prop and it would not pop off?
    Zeeland Michigan
    1,197
    They unscrew after hex nut is loosen . the shafts are threaded . this it the pdf of drive . http://traxxas.com/sites/default/fil...-driveline.pdf part 1529 show the prop shaft .
    1 Rusty VXL
    Jun 2014
    6
    Still do not know and am still clueless. what hex nut? I see no hex nut on my boat. Just the small allen head
    Mar 2003
    36,936
    That's what rhardy60 was referring to; the set screw/grub screw/allen head screw/etc.
    Notice how the factory prop shafts depicted in the PDF file linked to above are threaded. The props actually screw on to the prop shafts and are then further secured with set screws. You need to remove the set screws and then unscrew the props from the prop shafts.
    Jun 2014
    6
    I did and it will not turn. I removed the set screws then held the shaft behind the rudder and the prop would not budge. And yes I was turning them the right way. I will have to try some more
    Mar 2003
    36,936
    If I recall correctly, they will be on there pretty tight. (It has been a while since I've had to remove a prop from the factory prop shaft.)
    Zeeland Michigan
    1,197
    Then take the drive shaft off the u-joint and slide it out , then you'll be able to hold it better with pliers to unscrew the prop .
    look at the pdf i posted for you .
    1 Rusty VXL
    Mar 2003
    36,936
    If you use pliers, be sure that you do not damage or mar the smooth portion of the prop shafts if you plan on reusing them.
