    740
    Broken wire, how to fix?
    Ok, so i was driving like normal when I looked to see what last speed run pass was, i liked it and checked where volts and temp were, but i had a 0.0V reading. I could still drive, everything worked except voltage. Looked under lid and found this-
    It's blurry, but you can see the wire is broken. I don't know if i can re-solder that? Or do i need a new wire? Any help would be appreciated
    Riverton Utah
    4,419
    Well, it looks like it either snapped off, or came out of the connection. You "should" as far as I know be able to re solder that back together.
    740
    The pic is bad, but the wire did break off. The problem is i may or may not have bent the little pin trying to get it out 😅. Can I try and still get it out? Or just garbage it?
