Thread: Ouch!
    153
    Ouch!
    Busted the rear shock tower. Any good suggestions on upgrades?
    Mar 2006
    S.Wales,uk
    730
    FLM Or RPM.
    RPM will flex a bit and are a bit cheaper
    FLM are aluminium so do not flex, but if you have stock bulks which i see in the pic, you may find you are breaking bulks instead. If I was to do it all again I would swap the bulks and shock towers for RPM.
    " TRX3922a doesnt snap " IT SHATTERS !!!
    May 2006
    Wellington, New Zealand
    263
    Ue towers
    Sent from my GT-N7000 using Tapatalk
    Here in the UK, but Maxx back in New Zealand
    Apr 2013
    Wisconsin
    72
    Two aluminum towers back to back will give you the most strength
    Jun 2013
    120
    You could also use strips it will work most of the time and is a lot cheaper.
    Aug 2012
    Middle, Georgia
    1,217
    I ran an RPM shock tower on mine. It help up great. Make sure you also get some aluminum shock caps also. When the tower flexes it will cause them to pop off. Aluminum ones will solve that problem.
    Sep 2010
    Chicago, IL
    2,014
    I run rpm bulks with UE towers. Seems to be holding up fine but I havnt run my truck much with this setup. I strongly recomemd UE towers because they are the strongest on the marked and have many different shock positions. The issue as stated is that the aluminum tower will tend to break the stock bulks. If you have the extra $15, a pair of rpm rear bulks and a UE tower make for a great combo. Chances are you will break your bulkheads soon either way. FLM makes a great pair of aluminum bulks and even combo bulks, which are a great option if you have the money, although you then run the risk of breaking your stock chassis.
    Hope this didnt confuse you too much, but I tried to outline all your options
    Doublethink: 2+2=4 while 2+2=0
    Feb 2014
    12
    If that happened watch the bulkheads too there a common break just like the shock towers
