Results 1 to 8 of 8
    24
    Batteries Will Not Charge
    I have an EZ Peak charger and cannot get my NiMH batteries to charge. Some batteries are brand new, some have not been used since last November and some were used in the last 5 weeks but another brand but still would not charge on the EZ Peak. They would charge for about 20-30 minutes or less then the charge light will turn green. I have unplugged the battery and plugged it again and same thing. Has this happened to anyone else? Is the charger bad?
    12,290
    What is the voltage of the packs?
    24
    The voltage per pack is 8.4v(7-cell)
    Nov 2013
    73
    Is that the voltage after you pull the battery off the charger or just the voltage of the battery pack? Did you test the battery with a volt meter after the charge?
    Traxxas Stampede VXL 4X4
    24
    I checked the voltages and they are between 7.5 and 8 after I have tried to charge them.
    Nov 2013
    73
    Sounds like a bad charger. Try giving Traxxas a call.
    Mar 2014
    North Vancouver, BC
    515
    Have you tryed bumping up the chargers capacity. I am having the same issue with my traxxas 4200mah nimh battery. I set it at 4.2 amps on nimh charge and it would shut down after 10-15 minutes and say full but I knew it wasn't. Battery is new but would keep shutting off and say full. I don't know if it was the battery or charger but I went into the chargers program setting for capacity and bumped it up from 5000mah to 10,000mah and it started charging much longer up to 3700mah so I'm guessing the batts full now since it stopped about 3-4 times before at 10-15 min. intervals
    24
    I am not able to change the capacity of the charger, I have the EZ Peak 4-amp charger(2930).
