Results 1 to 13 of 13
Thread: 12mm hexes
    san jose
    111
    12mm hexes
    looking for 12mm hexes for the 6mm axles any recommandations thanks
    Middle Georgia
    44
    Use part 4954 or 4954x, which are parts from the Slayer. Or you can use Tekno RC parts for the Slash 4x4. They make a set of 12mm hexes that fit a 6mm shaft. Their upgraded driveshaft kit is upsized to 6mm shaft. You can buy the hexes alone without the kit. I use them on my E-Slayer, and my Summit LT conversion.
    4x4 Slash
    2x ERBE
    Summit
    1/16 Summit
    KB Rally
    Feb 2009
    718
    Just used the Tekno RC parts on mine TKR1654 and they work great for the 12mm hex. The 4954 traxxas part is actually a 14mm hex originally used on the slayer and the brushed version of the revo. I started going that direction but after an hour of sanding and only having one completed to show for it, I decided to go get something else and ended up with the tekno parts.
    One thing you will have to do is make the pin slot bigger as it is made for the smaller pin of the slash axles. I used a 2mm hex key and heated it with a torch then laid it across the pin slot till the hub was level with the wrench. pulled it off let it cool and then trimmed the flash with a hobby knife.
    If it didn't break you can do it again.
    Jan 2014
    Brawley, CA
    76
    Glad this was brought up. I'm waiting for my tekno hexes to get here. Now I know what to look for when installing
    2wd Slash , Tmaxx classic
    Long Beach, California
    6,638
    Traxxas make 12mm for XO-1 which are 6mm.
    | Rally GT8 Powered By CC | BackSl4sh Roadrunner |
    6,638
    here's what I'm referring in to
    Feb 2009
    718
    Even better and you don't have to enlarge the pin area on the adapter and they are captured. Only drawback is that they cost about 4 times as much as the plastic...but they should last longer.
    Aug 2013
    Brazoria, Texas
    1,138
    Are you planning to run slash wheels or beadlocks? The item mentioned a couple posts above will get you that.
    Revo 2.5 upgraded to 3.3.
    107
    Does anyone know if the XO-1 hex's (6869) referenced above use the large slayer pins versus the smaller pins the come from tekno? The pins in the tekno kit are the same size as the jato uses
    Feb 2009
    718
    Quote Originally Posted by Third Coast RC View Post
    The XO-1 ones listed above use the same threaded pin as the brushless revo.
    6,638
    The pin size is the same as the slayer.
    107
    Thanks for the quick replys, Aft and Hum. I bought the tekno's and they wobble. I'm going to try the XO-1's.
    Feb 2009
    718
    If you modify the tekno for the larger pin there is no wobble. Currently running them and they are as tight as the day I origanally installed them.
