Results 1 to 18 of 18
    362
    Questions on new MM2.
    So I finally took the jump to brushless and I am super pumped. I bought all the necessary mounting hardware to mount my new a Caste Creations mamba monster 2. I'm running trencher x's all around and nimh 4500's. The install went really well, but I have some questions.
    The guys at my local hobby shop recommended I run a 14 tooth pinion because i am using the nimh batts and I used a 68 tooth spur. So, the 14 T pinion wouldn't come in contact with the spur because the transmission would be on the motor can. So I just used the 18 tooth pinion that came stock with the MM2. I was wondering if it's fine if I run it like this? Also i don't know if it is the pinion/spur or transmission or the driveline but it sounds really "crackely" when I took it for a drive. I was wondering if this is usually what happens or if it's smoother.
    Also it Boggs a bit when I accelerate every once in a while.
    When I programmed the esc and motor I don't think I did it right. When I accelerate I think it isn't reaching full power. I re-programmed it like 10 times, when I drive it now the motor won't reverse. The esc will also beep once every once in a while.
    Also if anyone has any tips for it let me know! I will eventually be switching to lipos but I just don't have the $$ to buy it. I love the system though it's really cool and looks bad *****!!
    Aug 2013
    863
    It is bogging, and not reaching full power, because nimhs don't have the amps necessary to run properly a brushless system, it really needs some lipos to release all the power. The crackling sound could be anything from a stripped diff, driveshaft or a bad mesh.
    362
    Ok that makes sense. What lipos would you guys recommend?
    Aug 2010
    new hampshire
    1,773
    Quote Originally Posted by vwbug View Post
    SPC Lipos. Tom dose not have many in stock.They are well worth waiting for IMO. Promatch are some good lipos also
    http://www.spcracingbatteries.com/
    http://www.promatchracing.com/index.php
    kansas
    7,819
    so do you have reverse yet??
    Start with a good set of 2s, SMC, SPC, Traxxas top three.. higher the mAh the longer the run time, higher the C rating more punch. read in your MM2 manual the minimum amps required to power the system, more amps the better all my batts are well over 200 amps.
    2S 9000 x 28C = 252,000 divide 1000 = 252 amps
    2S 9400 x 60C = 564,000 divide 1000 = 564 amps
    ( mah x c rating / 1000 = amps)
    http://www.smc-racing.net/index.php?...tegory&path=67
    you did?
    Speed Control Programming Instructions
    The Castle Creations Mamba Max speed control should not need
    reprogramming with normal use. However, if you install a different
    radio system in your model, or change the transmitter’s throttle-neutral
    setting from 50/50 to 70/30, you will need to reprogram the speed
    control. Follow these instructions to reprogram the speed control:
    1. Install the batteries of your choice in the battery compartments and
    plug the batteries into the speed control.
    2. Switch on your transmitter.
    3. Hold full throttle while you switch on the Mamba Monster controller.
    After a few seconds, you will hear multiple tones and the
    RED LED will light.
    4. Hold full brake. After a few seconds, you will hear multiple tones
    and the YELLOW LED will light.
    5. Release the trigger to the neutral position. After a few seconds,
    you will hear multiple tones and ALL THE LEDs will light.
    another way to set you gear mesh by sound
    if you don't have your manual
    MM2 QUICK START GUIDE & Recalibrate ESC
    Post #300
    http://traxxas.com/forums/showthread...=1#post5400474
    piled almost everything else, might as well throw in this too.
    AOD's Links EMaxx
    Emaxx 101:
    EMAXX FAQ
    Lipo, LVC, Brushless & Battery charger/charging guides & purchasing links:
    TUTORIALS
    Refer to this to setup the Mamba Monster ( MMM ) esc for maximum performance:
    CASTLE LINK GUIDE
    Refer to this to find parts, upgrades, batts & chargers etc:
    USEFUL LINKS
    And direct from CastleCreations ( the esc manufacturers ):
    MMM FAQ
    Driver's ED Manual
    LED warning light meanings
    EMAXX 3906 UPGRADE GUIDE & LOW BUDGET BRUSHLESS OPTIONS
    362
    thanks snowfighter I am going to purchase a set of spc's soon would 5000's be powerful enough or should I go with 6500's?? Wow thanks 87gn! I will be re-programming it tomorrow! I have another question, does it matter what channel the fan Is plugged into?
    Aug 2013
    863
    The higher the mah means longer running time, make sure to get ones that fit, the batt compartments are tight, the fan can be plugged on any empty slot.
    362
    ok Is the fan suppose to be always on?
    Dec 2013
    Starr County, Texas
    618
    Yes fan is running constantly.
    Sent from my neXus⁴ using tapatalk 2
    <P4de VXL|Castle 3800kv|MM2|MIP|STRC|Proline|SPC>
    362
    ok thanks!
    Aug 2010
    new hampshire
    1,773
    Vwbug. I have the SPC 2s 6500 65c. I get about 40min. of run time and the fit nicely.
    Spc has a good warranty and great customer service.
    362
    sweet thanks!!
    Aug 2010
    new hampshire
    1,773
    Vwbug. 40min. of run time with stock gearing.
    Run time also depends how heavy your finger is .
    362
    and if the truck isnt in half
    Alright I got another question. So, Colorado decided to snow. In may, 16 days before summer break. So i thought sweet ill get the emaxx (now brushless) and go take a run. I then stopped and remembered that the fan must be removed but I was like, how? I don't see any screws but I see some tabs on the sides but i tried them and it dosent work. so if anyone knows how to take the fan off i would love to hear it.
    Edited for bypassing the language filter.
    Oct 2013
    Polk,NE
    133
    The tabs pus in toward the fan, quite hard I might add. Then the fan should sort of pop off, for lack of a better term.
    KCCO
    362
    ok thanks ill do that
    Melbourne, FL
    140
    I think the crackling sound you hear is just the sound of the motor. If you turn the output shaft by hand, you will feel that these monster motors are notchy by nature. When running your truck, if you let it coast to a stop in nuetral with no throttle/brake input, the crackling sound will be more pronounced. So, it is quite normal. I've heard this question asked before regarding these types of motors, and have experienced it myself. Hope that helps!
    E-Maxx 3903-Twin KD 700 HO - Wooden LCG Pede
    362
    ok thanks i noticed that when i would roll the truck and found it hard to roll. I got another batt question if i have a nimh batt that's casing is melted can i just wrap it in electrical tape and go run it?
