Results 1 to 10 of 10
Thread: Bellcrank
    Sep 2011
    Iowa City, Iowa, USA
    1,298
    Bellcrank
    What bellcrank upgrade do you recommend? I keep breaking the little plastic piece that goes under the driveshaft.
    1:16 Slash vxl
    Stampede 4x4 3800kv
    Rustler vxl
    Oct 2013
    369
    Bellcrank
    I have a hot racing one that i like, but they use brass bushings instead of the shoulder screws on the center peice i would recommend putting the shoulder screws in instead of the brass bushings
    Long Beach, California
    6,195
    mine just broke the other day so I pick up STRC ones since others have good result with them.
    | Rally GT8 Powered By CC |
    May 2013
    Erie, PA
    587
    +1 on the STRC bell crank. Either run the bell crank loose or get a servo with metal gears at the minimum. If its to tight it will more than likely strip the gears on the 2075 if thats what your still using...
    The message above or below may or may not be true
    Sep 2011
    1,298
    I have a metal gear xq power servo.
    1:16 Slash vxl
    Stampede 4x4 3800kv
    Rustler vxl
    May 2013
    Erie, PA
    587
    Quote Originally Posted by Jimdog View Post
    Great, shouldn't have any issues then. It will be a great upgrade for you if you keep breaking the stock one...
    Jul 2013
    Alberta
    24
    Another one for STRC bell crank
    Apr 2014
    North Tonawanda, NY
    65
    Have you set your steering end points? Upgrading bellcrank won't fix your problem unless you set end points, if you upgrade to aluminum you'll start stripping servos.
    BTW, hi all, new to the forum.
    Sep 2011
    1,298
    Yes I set the endpoints. I have a red strc bellcrank on the way!
    1:16 Slash vxl
    Stampede 4x4 3800kv
    Rustler vxl
    6,195
    I got mine yesterday, scroll down to post #618 http://traxxas.com/forums/showthread...gang&p=5703638
