    Apr 2014
    ilion ny
    light kit and dual servo set up
    Any one running a light kit with a dual steering servo set up? Already have dual steering servo set up. I'm looking to do a light kit but I seen you have to mount part of the light kit where the 2nd servo would go. Any other way to mount light kit? Pictures would be great.
    Jan 2014
    Lehi, Ut
    264
    I don't have the light kit, I haven't seen one either, but if it usually plugs into the second servo slot then it should work with any of the other ports (assuming the light kit doesn't have turn signals. If so the lights should work but the signals wouldn't). From what I understand the power rails on the receiver are all connected together.
    1/16 Summit beadlocks with 2.2 rock lizards
    Apr 2014
    11
    I need to do dual servo's. I am gonna upgrade to these I think, these might help http://www.ebay.com/itm/Traxxas-1-16...item338cd6944c these might help so yoiu don't need dual but one is strong enough. I don't have a light kit, but that might help for for only needing one servo.
    Alma, Michigan
    12,291
    A single strong servo is always better than two. When putting a second servo in, they must be 100% in sync... which is nearly impossible; and is impossible with the stock linkage because it is not adjustable. Due to the non-adjustable linkage, I feel Traxxas did not intend to have the 16th steer with dual servos... another clue is that the light kit switch takes up a servo spot.
    RC's that come with dual servos... like the Revo, Summit, and eMaxx... some of those guys (me included) are paying big bucks to switch to a single servo setup. That gave me a big clue right there!
    I ran a $30 Blue Bird 390 in my 16ths... hundreds of packs and it was still going strong when I sold it; and I think it was still going strong when he sold it!
    Jan 2014
    Polson, MT
    524
    I just broke my stock steering pole, and the arm on servo saver. I want to try aluminum but looks like GH's are discontinued. Any suggestions?
    Those who forfeit liberty 4 security get neither
    May 2014
    17
    "The toyz" on eBay sells an aliminum steering set up by hot racing.
    Where the Summit takes me.
    59
    I don't have dual servos but I did manage to rig up my own lighting kit. I found some old tea lights and wired them all in parallel to a 9V battery. Presto, the battery lasts forever and I turn it on when I want to, not every time the RX turns on.
    1/16 Blue Summit
    "It's life, not drama." -Me
    Jun 2003
    Estes Park, CO
    921
    I run dual servos and lights on my newer build. I'm running a spektrum radio, steering and aux ports are for the servos and I use the bind port for the lights and capacitor.
    Dye-no-mite Pow-er Go Fast, Wirrrrr Screeeech BOOM
