Results 1 to 24 of 24
    Mojave Desert
    1,708
    Installed the Brushless System
    Finally got around to installing my Toro 1/18th brushless system and man was it a chore! had a hard time getting the mesh right. Maybe I was doing it the hard way. Anyway, here are some pics
    My LHS only charged $5 to solder on the TRX connector.
    Used 2-sided Velcro tape to hold down the ESC
    Here It is Installed
    Feb 2014
    161
    Looks good, my toro should be here on Tuesday. Can't wait to start breaking stuff!!! Lol
    Mojave Desert
    1,708
    lol yea I took it easy on the first outing. BUT I noticed on a full throttle run it didn't have nearly as much speed as the brushed motor it came with...maybe a bigger pinion?
    Feb 2014
    161
    Syrics had a 15t rc18 pinion that he used. I ordered and received it already. You can see the difference in this photo.
    Mojave Desert
    1,708
    I just ordered the 15 tooth as well
    Feb 2014
    161
    Team toro!!!! 👹
    Mojave Desert
    1,708
    Kind of let loose with the Teton and its new system today and I think, if not the same, it's slightly slower than the stock motor/esc combo. My Teton also has the bad case of the clicking in the diffs so I guess this is what's slowing it down maybe??? The good thing about this setup is the temps...I was shocked at how cool this thing was every time I checked it. Just was hoping for a lil more speed. The 15tooth pinion I have on the way will help though.
    15,894
    Did you calibrate the ESC after installation?
    Alt-248 on the number pad =
    Mar 2014
    93
    Quote Originally Posted by G-Rustler View Post
    Get yourself a 3s lipo.
    I didn't run my toro setup without one.
    It does 35mph on the Gens Ace 1300Mah 3s I put in mine.
    Mojave Desert
    1,708
    Can you elaborate on this???
    Feb 2014
    161
    Mojave Desert
    1,708
    Quote Originally Posted by Syrics14 View Post
    will put on my must get list. is it the same size as the SPC 2s 2500mah battery or at least close in size?
    Mojave Desert
    1,708
    oh wow!!! I see
    Will try this now. I guess that's what I get for being so excited to install the system that I didn't fully read the manual. I have this exact same manual but only used it to sync the transmitter then tossed it to the side lol
    wait hold on...this process is the process I used to sync the transmitter. I did this. Got excited too quick. I thought you guys were showing me another process.
    15,894
    All ESCs need to be calibrated to the radio transmitter used. The procedures vary, but all need full forward and full reverse to be defined.
    Mojave Desert
    1,708
    well I "seem" to have full forward throttle. the reverse is 50% for sure because it isn't as powerful as the forward throttle.
    Mojave Desert
    1,708
    Tomorrow i'll try to upload a vid of the performance so you guys can let me know if something is wrong or not.
    15,894
    If the ESC included calibration instructions, be sure to perform the procedure.
    Mojave Desert
    1,708
    I did, right when I installed it. Just did it again. Same instructions as the link above from @Yinzer...same results. still has stock speed imo. would think it would be faster considering its a brushless combo. I'm beginning to think it has something to do with the clicking gears. It clicks when I go on the grass with it or full throttle from dead stop.
    Feb 2014
    161
    My sons grave digger teton was clicking bad and lost performance. The front wheels were dragging the back ones.
    I took apart the rear diff and it had missing teeth on the spider gears. Replaced them with new and it's running like a champ again.
    Mojave Desert
    1,708
    I might have to do the same thing. It's my front diff though that's making the clicking sound.
    this is what I need to replace right?
    http://www.ebay.com/itm/351036069682
    Feb 2014
    161
    Yup, just reuse your metal gear that came with the truck not that plastic turd in the kit.
    Mojave Desert
    1,708
    Quote Originally Posted by Yinzer View Post
    cool...thanks man
    Mar 2014
    93
    Yeah it is actually a tad smaller if I recall right.
    Mojave Desert
    1,708
    even better!
