    Feb 2014
    Boston, MA
    133
    EZ Peak plus. Nimh question
    Set the charger on a saved battery profile. 4.5 Amps for a 5000mah battery. Instead of reading full is beeped and blinked CAPA and the charger showed 5000mah exactly. So did it auto shutoff at 5000 or didn't an error occur?
    I set the delta peak to lowest setting of 5 and battery seemed hot. Any help would be appreciated.
    Alma, Michigan
    12,291
    Did you shut off the capacity limitation?
    Dec 2013
    Starr County, Texas
    682
    Capacity limiter is set at 5000mah. Turn it off or increase it to 6000. Under program mode are the settings.
    Sent from my neXus⁴ using tapatalk 2
    <P4de VXL|Castle 3800kv|MM2|MIP|STRC|Proline|SPC>
    Feb 2014
    Boston, MA
    133
    Yes. That was it guys. Stupid me. Was set at 5000. Thanks!
