    Aug 2013
    6
    Sand in the gearbox
    I have recently bought a Teton. It's a nice little truck, but I keep getting tiny pieces of sand in the pinion/spur area that always seem to get into the teeth and then cause a clicking sound while slowly destroying the spur and pinion teeth. It's easy to get it out of the teeth, but it gets tiring to continually do that. I drive in fairly sandy conditions as the off-road conditions around where I live just are sandy--nothing I can do about it.
    Does anyone have a suggested mod about how to better seal that rear gearbox? I suspect it must be getting in through extra space where the center drive shaft enters through.
    (FYI, to run my slash 4x4 in these same conditions I have to use the proline overtray and the aluminum tube drive shaft mod to keep enough sand out of the center area so I don't have to clean it out every 5 minutes. I was hoping something similar would be found for the Teton.)
    Mar 2014
    21
    Mabye a rubber seal.. I have no problems like that make sure it's tightened down
    Jul 2014
    Is there a seal for the gear box? I have had the same issue twice in the first thee runs of the battery. A clicking noise coming from the gear box and it turned out to be a small rock. It takes a good while to get in there to clean it (at least for me) and I don't want to have to keep doing that every time I use the truck.
    Other then that, it seems to be awesome!
    May 2014
    74
    I noticed the same thing on the first time I took the truck apart. To see if the sand was indeed coming in through the center drive shaft opening, I sealed the back with tape. It did help keep sand out, so some sort of a seal is what you need.
    Here's a pic of what I did:
    LaTrax Teton
    Thunder Tiger Phoenix STII
    Jul 2014
    Haha nice! Well I broke down and did the same thing. I also put a cardboard cut out that fit in front of the gear box because I figured the dust was coming in through there.
    Jul 2014
    This is how I fixed my gearbox "leak". It's pretty obvious were the sand and debris gets in. Just look at the big gap between the mainshaft and the housing.
    I put a piece of siliconehose on the main shaft so it barely touches the housing. Should keep most of the debris out.
