Results 1 to 8 of 8
    SLC, Utah
    3,432
    Alternate Shocks that fit the Teton
    Hey Guys,
    Sharing my findings of the Teton. There are two other shocks from other vehicles that are IDENTICAL size of the Teton...
    Reason I found this, Is had a customer (really attractive Mom btw) whos son kept breaking the shocks, here:
    SO... my finds concluded, you can mount the Dromida MT.18 shocks on here, and it a DIRECT fit.. exact size, down to the MM>
    Here is the results, I even think they look better, so I will be doing this to my Dromida.
    Here is what you need for mounting hardware. Although the ball cups at the bottom look similar, they are different sizes. By just alittle, but still.. you need the Dromida ones
    The Dromida Part number for the shocks are: DIDC1026. Plus you need the Springs. For a pair of the shocks, its half the price of the stock Traxxas ones.
    Also....... The shocks from the HPI Mini Recon, are ALSO IDENTICAL size to the Teton. Same Style mounts also... 15.99 a pair for those, so there are two alternatives to the Traxxas shocks, in case anyone is breaking a lot, and they are still back ordered. Something we have been having a hard time with.
    HPI105519
    Which means.... You can mount these upgrade HPI Recon Shocks.
    Part number:HPI 105522 35.99
    So far all the ones I've found, look like they were basically made from the same OEM> Alittle different, but shafts are identical, bottom mounts are identical, and they all are very similar. Chances are they are they size, they will fit..
    Also, How is the feel of the Dromida on the Teton? PERFECT.... Think they feel better than stock even with their springs. This is what I am gonna do to mine...
    4,401
    Nice, thanks for sharing! I'll have to pick up a set.
    13,325
    Cool find, diggin' the gold hpi shocks. The hpi ball cups fit the teton balls? That would def sway me from buying the associated shocks and balls.
    EDIT:
    The Dromida Part number for the shocks are: DIDC1016. Plus you need the Springs. For a pair of the shocks, its half the price of the stock Traxxas ones.
    Fixed the part number
    thanks Loot 8)
    SLC, Utah
    3,432
    They might Rag, Im not sure. I know one thing, the Dromida ball cups are just a little tiny different, so for dromida, you need different ones. Tomorrow il take a look at the Recon shocks, and see what I can come up with.
    Crazy thing. The Traxxas, Dromida, and Recon shocks, are the EXACT same size...
    Feb 2014
    17
    I broke the shafts on both my stock front shocks, and couldn't find replacements in stock anywhere - so I ordered a couple sets of the HPI Mini Recons - the basic 105591 ones. They do in fact fit without modification, but I don't know how good they are. Mine won't fully rebound when compressed. They seem to be sticking.
    The springs also appear to be different rates than the stock Teton springs, but you can easily swap the Teton springs onto the HPI Mini Recon shocks. I did so, but the shocks still don't fully rebound.
    I'm a newb... so feel free to tell me there's an easy fix to this. Much obliged...
    Feb 2014
    161
    Quote Originally Posted by Boldfin View Post
    Sounds like the ball studs are to tight. If the shock can't move freely on the ball studs then it won't rebound. Hope that helps.
    13,325
    Checked out the dromida shocks the other day. I did not have my teton, but at quick glance they seemed to be a much bigger bore than the teton shocks.
    Feb 2014
    17
    Quote Originally Posted by Yinzer View Post
    I think you're right. It was really hard to get the mini recon shocks to fit on the Teton ball studs. They do snap on, but they definitely don't move freely. I guess I need to order a set of HPI mini recon ball studs. Thanks.
