Results 1 to 15 of 15
    Mar 2014
    27
    NiCD or NiMh batteries?
    I know NiMh batteries last longer (and cost more) but the charging/discharging procedures are pretty complex. And if not done properly, can shorten battery life. Just wondering if NiCD batteries would last just as long with the simpler charging procedures for less cost.
    N. Idaho... Da Sticks!
    3,378
    Ummmm.... no.
    NiMH are actually very cheap right now and charging them is very simple and no more complicated than charging a NiCD, and A LOT easier to charge than LiPos. NiCDs are actually harder to take care of than NiMH and will get a charge memory if not cycled properly. Plus, NiMHs come in higher current ratings.
    Mar 2014
    27
    I dunno, this looks pretty complicated to me: http://batteryuniversity.com/learn/a..._metal_hydride
    Alma, Michigan
    12,290
    The only thing that makes it more complex is how the software in the charger needs to be programed.
    Set your charger for NiMH and the amps (mAh/1,000) and you are all set.
    Run your RC until it starts to slow and recharge after they cool.
    Keep them fully charged when not in use.
    Not all that complex.
    Sep 2011
    Iowa City, Iowa, USA
    1,678
    Can you still buy nicd batteries for rc? The capacity is VERY low compared to nimh batteries and getting rid of them is hard because they are toxic. Most chargers use the same setting for the two so charging them is no different other than nicd batteries would require a full discharge before charging.
    1:16 Slash VXL
    Stampede 4x4 3800kv
    Rustler VXL
    3,378
    Quote Originally Posted by chrysigon View Post
    OK, good research here. But, like Jimmy said, the charger is doing most of the work for you, you just need to make sure that the charging is set to the right chemisty and the proprer amperage.
    People normally don't mess NiMHs when charging, they normally mess them up when they are running them. During the run there will be a point were the RC's max speed drastically and suddenly drops, this happens when the pack 'dumps'. At this point you should stop the RC and pull the battery. A lot of people keep running the RC until it can no longer move, which over-discharges the pack and heats it up, a lot, both will kill your cells.
    Mar 2014
    27
    This the charger I have. Is it safe to say that to charge 3300Mah battery, I should charge it at 3.3 amps?
    Can I splice two black and red wires to charge 2 batteries at once?
    Sep 2011
    1,678
    It would have to be black to red for nimh batteries. They have to be connected in series.
    1:16 Slash VXL
    Stampede 4x4 3800kv
    Rustler VXL
    Mar 2014
    27
    OK, are you saying, one battery is red to red and black to black and the other one is red to black and black to red?
    Alma, Michigan
    12,290
    I advise against charging NiMH in series or parallel. There are already quite a few cells not being monitored individually with in 1 pack, let alone adding a whole slew of others with another pack. It is a good way to overcharge cells and permanently damage them.
    3,378
    Now you are making in complicated. Again, agreeing with Jimmy, charge one at a time. Charging at 1C (3.3amps for a 3300mha pack) mathmatically will take an hour, but the actual time will be 40 - 50 minutes.
    Jan 2014
    Ohio
    371
    Keep it simple ; charge one at a time. Since you leave them fully charged you can charge up several after you run for the next time. Don
    Central KS
    1,073
    When I started in the hobby I ran NiMh for a while. Other than going brushless the best upgrade I ever made was switching to LiPo batteries.
    I have heard that LiFe batteries are "safer" and charge faster than LiPo batteries, but have lower capacities than LiPo batteries. Just a thought.
    The performance improvement from NiMh to LiPo is really incredible, though. Making the switch was worth every penny!
    What broke, uh, needs upgrading now?
    740
    Now lipos are actually cheaper than nimh... Well worth the upgrade
    Central KS
    1,073
    Quote Originally Posted by rcnewbie1234 View Post
    I was a little intimidated by LiPos b4 I made the switch but with a little effort and care they are the best thing since sliced bread...
    After I made the switch I only regretted the $ I spent on NiMh. But I never looked back!
